Toshiba L735 DABU5DMB8e0 - NO display
Domas
Admin
Admin
Re: Toshiba L735 DABU5DMB8e0 - NO display
Post by Domas »
Tried-same
sir change your bios ic
Domas
Admin
Admin
Post by Domas »
Changed - same.
Domas
Admin
Admin
Post by Domas »
Changed EC - same..
Convert to UMA - same..
Domas
Admin
Admin
Post by Domas »
Will try replace pch
Bad VS good cpu socket tester
iamkamalrandhawa
Post by iamkamalrandhawa »
I am 100% sure this is not repairable now. :p
Domas
Admin
Admin
Post by Domas »
its pch either cpu socket, Kamal :)
I think you can check all capacitor and mosfet that drive the power for pch
maybe they are short so the pch temp goes high
alexasha8311
Post by alexasha8311 »
Domas wrote:will try, thanks
any compatible to NPCE791 ?
npce795
alexasha8311
Domas wrote:Model: Toshiba L735
Board : DABU5DMB8e0 REV:E
After TOKIN change mobo turns on , current 0.9-1.0A. NO display.
PCH heats up, changed it - same
Flashed both bios - same
Converted DIS -> UMA -same
Where could be problem?
HOW TO CONVERT TOSHIBA L735 GRAPHICS TO NON GRAPHICS.
Users browsing this forum: No registered users and 113 guests
