Page 1 of 1
m5030 nodisplya
Posted: Mon Mar 21, 2016 2:00 am
by ihrasameen
when the adapter is connetcted the lap will switch on auto maticly but no display all voltag ok. bios re progeamed same status. i need a help
Re: m5030 nodisplya
Posted: Mon Mar 21, 2016 5:33 pm
by Domas
Re: m5030 nodisplya
Posted: Mon Mar 21, 2016 6:54 pm
by esmat-fadak
check all voltages the ACIN goes through it
and also check voltage like
3.3v alw and 5 alw and also Ic controller for these two voltages
Re: m5030 nodisplya
Posted: Tue Mar 22, 2016 7:48 am
by rajnish
if your laptop AMD check all voltages
than you check processor
next you check AMD chip
Re: m5030 nodisplya
Posted: Wed Mar 23, 2016 3:29 am
by avdesh1
please share beep codes as dell laptop
by the motherboard if 8 beeps go for igp chip else on 7 go 4 cpu
Re: m5030 nodisplya
Posted: Wed Mar 23, 2016 7:32 am
by rajeshkumar45
SHARE UR MOTHERBOARD PART NUMBER WHEN WE SOLVE UR PROBLEM PERFECTLY
Re: m5030 nodisplya
Posted: Wed Mar 23, 2016 4:33 pm
by Dhirendra Gaur
you can replace AMD chipset not succes reballing
Re: m5030 nodisplya
Posted: Wed Mar 23, 2016 6:13 pm
by avdesh1
chip replacement never be a option first search a question why problem priests then go solution
u having dell pcb its debug codes and debug system soo inhance use it
