Page 1 of 1
Code list on IC Richtek
Posted: Wed Aug 10, 2016 6:09 am
by sunilpatel
Here is a list of some ic code Ricktek brands that sometimes confusing .. Hopefully it canhelp to colleagues in need:
RT8202APQW / DJ=CA
RT8223M / EQ=ED
RT8206A
RT8206B
RT8205A / CJ=DA
RT8209A / FH=BL
RT8167B
RT8205CGQW / CL=CD
RT8202PQW
RT8205BGQW / CK=CL
RT8011GQW
RT8010GQW
RT8204CGQW / H6=BE
RT8239CZQW / JD=CJ
RT9513GQW
RT8208AGQW / FF=BK
RT8208BGQW
RT8015AGQW / EL=CA
RT9364GQW
RT8205EGQW / DT=CB
RT8207AGQW / DH=CG
RT8209BGQW / AO=CB
RT8451GQW
RT8207L
RT8058 / CB=CC
RT9511
RT8204AGQW / JL=BK
RT8204BGWQ / FR=AH
RT8223B / DS=CA
RT9618 / EF=
Try to see the picture below .. hopefully can help colleagues all.
Initially sy also be confused with the code on ic2 latest laptop, because it uses code ..example EQ = EF
From these images a sense sdh sy adequately represent the type RTxxx ic code2.
so if we want to change the ic they will be the most important code initially FH =, for thecode behind it does not matter, because the only date code ...
Hopefully Helpful
Re: Code list on IC Richtek
Posted: Wed Aug 10, 2016 11:33 am
by javed
thanks sir
