Page 1 of 1
HP COMPAQ CQ57 AMD Built In CPU NO POWER
Posted: Sat Apr 09, 2016 12:07 pm
by faiyaazs
PROBLEM:- NO POWER DC JACK LIGHT NOT GLOW
SOLUTION:-
1ST I HAVE CHECK DC JACK, JACK OK,
2ND CHECK SORTING IN MOTHERBOARD, I HAVE FOUND TPS51123 IC IS HEATING WHEN INSERT DC SUPPLY,
THEN I HAVE CHECK TPS51123 TPS NOT SORT THEN I CHECK OTHER PART TO CONNECTED TPS IC,
FOUND 1 CAP IS SHORT NEAR IO REMOVED CAP AND CHECK CAP IS OK, THEN I HAVE REMOVE IO,
AND CHECK SORTING, SHORTING IS REMOVE, THEN REPLACE IO IC ITE8518E, CONNECT DC SUPPLY JACK LIGHT IS GLOW,
LAPTOP POWER ON AND WORKING OK.
Re: HP COMPAQ CQ57 AMD Built In CPU
Posted: Sat Apr 09, 2016 7:28 pm
by esmat-fadak
Re: HP COMPAQ CQ57 AMD Built In CPU NO POWER
Posted: Sun May 15, 2016 8:07 am
by alexasha8311
nice job
Posted: Mon May 23, 2016 7:30 pm
by shiva0525
Good work
Posted: Thu May 26, 2016 1:37 am
by mohamedsaid
very goood troubleshoooting thanks
Posted: Thu Jun 16, 2016 9:42 am
by sunilpatel
thanks very good
Posted: Fri Jun 17, 2016 5:18 am
by javed
good job sir
Posted: Sun Jan 15, 2017 11:34 pm
by pdewida897
GOOOOOD WORK
Posted: Sun Feb 19, 2017 9:13 am
by wajhulla
