MODEL MS-7525 VER:1.0
PROBLEM NO DISPLAY
DEBUG ERROR CODE 0B0B
RAM SOUND BEEP COMING AFTER THIS ERROR SHOW
BIOS FLASH AFETR SAME PROBLEM
PLZ HELP
ms-7525 display problem
1.Board model/number
2.Describe problem clearly
3.What you did to solve problem
Re: ms-7525 display problem
try changing ur ram or flash another bios sometimes bios is not matched the ic
i am change the bios ok m/b but same
Dry solder the ram slot at the back side of the board.
reflow north bridge
wash board and reflow some time ...
change the clock this is smbus & smclck filure
