PCH FAULTY OR NOT?
ravichouhan
Cash on hand: Locked
Has thanked: 0
Been thanked: 6 times
PCH FAULTY OR NOT?
Post by ravichouhan » Sun Sep 18, 2016 9:27 pm
2. HOW TO CONFIRM PCH FAULTY OR DRY?
gurmeet singh
Has thanked: 0
Been thanked: 4 times
Re: PCH FAULTY OR NOT?
Post by gurmeet singh » Mon Sep 19, 2016 9:27 pm
Check rtc section working conditions. If rtc working good then check ec working conditions . If ec working conditions meats to requirement then check bios if s5 is not released .
Has thanked: 4 times
Been thanked: 30 times
Post by aamkaachaar » Fri Sep 23, 2016 6:40 pm
To varify PCH is Faulty
On cold test Check Pin8 on Main bios if the resistance is low or 0 and there is no other shorting in 3.3V line components then u can be pretty sure that u have problem with ur PCH
Check the SUSB and SUSC resistance with respect to ground ...if low then it may be one of the reason for PCH gone bad
other physical conditional also matter and sometimes like in 5050 board u find GFX coil shorted without cpu load ...in these conditions
we can make sure pch is faulty...the capcitor on PCH itselfs shows short ...
Thanks
sunil
[ Post made via Linux Laptop ] Image
These users thanked the author aamkaachaar for the post:
rxtxgnd01 (Mon Jul 02, 2018 12:35 am)
Rating: 14.29%
ESC
Has thanked: 0
Been thanked: 0
Post by ESC » Fri Mar 09, 2018 1:08 pm
Nice Info Sir.. Thanx
crowntoy99
Has thanked: 2 times
Been thanked: 0
Post by crowntoy99 » Thu Mar 28, 2019 4:09 am
good jobe
BarryRag
Has thanked: 0
Been thanked: 0
PCH FAULTY OR NOT
Post by BarryRag » Sat Jul 13, 2019 5:10 pm
Hi, not sure if you got sorted but have you made sure the small switch under the batteries is set to alkeline? That gave me a similar issue?
