Toshiba NB10-A problem
zlonx
Post by zlonx »
Toshiba NB10-A
not powering on, when power source is plug in battery or ac, the power led comes on bright. the signal for led indicator comes from the i/o controller yes? what does this mean?
thank you
bluestone
Re: Toshiba NB10-A problem
Post by bluestone »
Try to flash the bios or EC if there is one available
zlonx
Post by zlonx »
i tried flashing both. but same issue. with an ac adapter plug in, the power is flashing brighter. it does not switch off completely. its on always but becomes brighter and blinking. do you think the I/O controller is bad? its an IT8528E chip, it has an external spi ship for the EC. if i replace the I/O chip, does it require reprogramming too?
check acin, ec reset signal first
zlonx
Post by zlonx »
do you have schematic for this model? tnx
zlonx
Post by zlonx »
manage to switch this on for less than a second. power button blinks. 3 & 5v is now present after switch on.
+vgfx_core
+vcore
those are shorted to ground (diode mode) going to the N2840 chip. probably needs reballing or even replacement.
